Latest post 05-28-2008 4:26 AM by Alex. 5 replies.
Page 1 of 1 (6 items)
  • 05-25-2008 7:38 AM
    • Olof
    • Top 500 Contributor
    • Joined on 05-12-2007
    • Posts 141
    BeoLab3 and MacBookPro
    Is it possible to connect a BeoLab3 temporarily with a MacBookPro (to listen musik) and/or with a BeoVison MX 4000, without disconnecting cables ?
  • 05-25-2008 9:25 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: BeoLab3 and MacBookPro
    Connect the MacBook Pro into the Audio-Aux link input on the MX4000 with a minijack > 5-pin DIN cable, which you can get at most B&O dealers, and Lifestyle-AV. Make sure the MX4000 is in Picture Option 2 (or if you have a Beo4, it's called 'V.Opt' and then the number 2). On a BeoLink 1000, pressing any of the audio sources, such as CD will activate the Audio-Aux input, and the same goes for Beo4.
    If your MX is a 4002 and not a 4000, you'll need to look at doing things another way...
     Weekly top artists:
  • 05-25-2008 12:24 PM In reply to
    • Olof
    • Posts 141
    Thanks i checked it, my MX is a 4200, does it work in the same way ?
  • 05-25-2008 1:05 PM In reply to
    • Alex
    • Posts 2,990
    No, it won't. You'll need a minijack - 2x phono cable, which can be bought in most B&O dealerships (it's the same cable used for connecting an iPod to a BeoSound 4).
    This will then go into the 'Camcord' input on your MX4200, which is activated with the 'Camcord' function in the 'List' menu on your Beo4.
     Weekly top artists:
  • 05-28-2008 12:14 AM In reply to
    • Olof
    • Posts 141
    Hmm, my MX 4200 has a Masterlink jack. How should that work ?
  • 05-28-2008 4:26 AM In reply to
    • Alex
    • Posts 2,990
    Ignore that - just use the Camcord input, which looks like 3 little circular connections, yellow, white and red. Connect the cable you'll get from your B&O dealer (or wherever else) into the white and red connections and activate 'Camcord' on your remote.
     Weekly top artists:
