Latest post 05-15-2008 5:02 AM by joeyboygolf. 1 replies.
Page 1 of 1 (2 items)
  • 05-14-2008 9:55 PM
    How do I re-attach the steel cable in a BeoSystem 2500?
    How do I re-attach the steel cable that drives the glass doors in a BeoSystem 2500? I think I have everything figured out except how the two ends wrap around the cam.
    Thanks!
  • 05-15-2008 5:02 AM In reply to
    Re: How do I re-attach the steel cable in a BeoSystem 2500?
    Easier to look at a picture than describe and even then it's a bit hit and miss!!
    The service manual has a drawing which should help. Suggest that you upgrade your membership to silver or gold and download the manual.
    Regards Graham
