I've just performed this with my MC120.2's and I found it very easy.
A couple of tips to be going along with.
1. Snip the wire off the old capacitors and pull the main part off of the board before you apply the soldering iron. This stops the capacitor from acting as a heat sink and makes removing the tails of the wires so much easier.
2. The new capacitors should also be glued to the board- don't ask why but apparently this is how it's done.
3. Buy a kit from Dillen if you're as lazy as me - saves trawling around trying to find the correct spec'ed replacements and positioning instructions are included. I found this invaluable as the text on the old ones had all but disappeared.
Chris.
