Dear experts !
I am not a B&O expert and this is my first post to this forum:
A while ago I bought an Avant TV with Dolby and now I would like to use the dolby option. I have bought a MCL2P at ebay to be able to use the passive front speakers I already have. I have connected the Avant to the MCL2P with a 1:1 8-pole DIN cable. When I switch on the Avant the MCL2P light switches from red to green.
Now I am starting to have problems or making some mistake:
I have put 2-pole 'dot-bar' plugs to my speakers that I can plug into the 4-pole speaker outputs of MCL2P, the other 2 dot - holes left unconnected. This leads to the behaviour that speakers make a loud 'blob', the MCL2P switches to red and does not work for a minute or so.
I am not familiar with the 4-pole 'speakerlink' connectors nor do I have a plug for them but I thought I could use the standard 2-pole speaker plugs. Maybe that was wrong ? Or should it work and there is something wrong with the MCL2P ? I I am happy for any kind of answer !
Michael Max
