Yesterday, I placed my order with B&O for my new system, which will include a BS3.
I'd love to hear some experiences and advice from some other BS3 owners.
1. Wire management: I understand how all the wires plug in the front and run to the back on either side of the unit.  I've not seen a BS3 that wasn't already in a cabinet, so I'm curious how the wires exit the device.  Are they all channeled to come out the rear center, on either the left of right sides?  For example, if the BS3 was on the top of a cabinet, would one see the jumble of wires one sees from the "typical" receiver?
2.  How much heat does the BS3 generate? Will it be OK to place it in an a/v cabinet with limited air flow, or does it need to be more "in the open" to vent off heat?
How are you integrating the BS3 in your systems?  Wall mounted? Inside a cabinet? On a shelf? Other? Any pics of your set-up?
Thanks, as always, for your input and insights.
