Firstly; thanks for your responses.
Secondly; me and DIY really don't go!
I would be buying an audio system, perhaps a beosound 4 and a set out loudspeakers, either 6000 or Beolab 3's. I would like them all mounted on the wall which (i think, as i havent actually moved in to my new house yet) is plasterboard.
Ideally i would like B&O or a.n.other to come in and do everything; run cables, mount wall brackets and hand me the remote when i get home from work! Do B&O repair any plasterboard following installation?
Obviously the price varies depending on the level of install and i would assume that what i described above is fairly standard for a B&O customer?
Chris
