Latest post 04-28-2008 8:54 AM by burantek. 2 replies.
Page 1 of 1 (3 items)
  • 04-27-2008 6:45 PM
    ml/mcl converter
    hi all,
    read in the product section about the above item...
    that it could control up to (4) rooms w/ passives. does that mean that i would have volume control using a mcl2a (which you normally wouldn't)
    i.e. i was picturing...
     master --> mcl2av+mcl2p in each passive link room
     vs.
     master --> ml/mcl converter+mcl2a in the first passive room and then just an mcl2a in each additional passive room
    sorry, i have been studying link setups for some time now -and frankly -i need a break.
    thanks in advance,
    • B&o bottle opener
  • 04-27-2008 6:50 PM In reply to
    • Christian
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 626
    Re: ml/mcl converter
    All volume control is done by the MCL/ML or the MCL-2P.
    So the answer would be:
    Separate volume control in each room
    vs.
    The same volume in all link rooms
    referring to your post.
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
  • 04-28-2008 8:54 AM In reply to
    makes perfect sense, thx!
    honestly, i have become so absorbed in all this "linking" -sometimes i just get bewildered.
    at any rate, i see little need to change the downstream layout. the ml/mcl converter will simply allow the bs9000 to replace a bm4500 in a mcl network as i see it.
    i'll leave the rest alone.
    thx!
    • B&o bottle opener
