Latest post 04-27-2008 1:16 PM by 355f. 1 replies.
Page 1 of 1 (2 items)
  • 04-27-2008 12:35 PM
    Problems using Panasonic Hard Drive/DVD with B&O LX2502
    Hi folks,
    I bought my parents a Pansonic DMREX77 hard disc/dvd recorder for Christmas, but it didn't work properly with their LX2502. It would play DVDs OK, but when I accessed the hard drive menu system, it wouldn't even give a steady image on the screen, and the menus constantly drifted cross the screen.
    I decided in the end that there must be a fault with the Panasonic, as everything else they've plugged into the B&O via the SCART socket has worked fine. (Panasonic VHS recorder, DVD player also Panasonic, and a Freeview box that can't remember the manufacturer of). Send the Panasonic back and got a replacement, but they're now having trouble getting this one to work too.
    Does anyone have any experience of similar problems? Is there some incompatibility - from other posts it doesn't sound like it as there seem to be plenty of folks using Panasonic gear with B&O TVs. Any advice would be very much appreciated, as it's pretty disappointing to still be having problems 4 months after it was first bought. Thanks.
  • 04-27-2008 1:16 PM In reply to
    • 355f
    • Top 100 Contributor
    • Joined on 04-19-2007
    • Posts 655
    Re: Problems using Panasonic Hard Drive/DVD with B&O LX2502
    The panasonic comes with 16.9 as default. You need to change this to 4.3 output as this would give the symptoms you describe
