Latest post 04-23-2008 5:03 AM by meandmyshadow. 1 replies.
Page 1 of 1 (2 items)
  • 04-22-2008 10:44 PM
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    My beosound 3 is haunted
    I was helping my daughter with her homework tonight when, all of a sudden, my beosound 3 (my kitchen radio) started playing.  It disobeys my every command, and seems to mock me (changing the volume will scroll through some of the songs, I can sometimes hear the "tink" when I touch a command, but it does nothing).  Luckily, it is not playing loudly.  I have unplugged and am allowing nature to take its course.
    Has this happened to others?  I seem to recall something about there being problems with the touch pad, but when I search on "beosound 3", it get mostly beosound 3xxx articles (not many entries tagged with beosound 3, either).... was I dreaming this?
    On the positive side, it's just under 2 years old so the 3 yr warranty should make it good as new, right?
    Stan
    Filed under:
  • 04-23-2008 5:03 AM In reply to
    Re: My beosound 3 is haunted
    Contact your dealer, they will replace the touch pad under warranty, it's a known fault.
