Hello all!
I have a Mac (MacBook Pro) and I am interested to store some of my music on it (or USB drive) and play it through the house on my B&O equipment, and vice versa. I looked in the forum and I know that there is a solution called BeoPort. However a have 2 questions and your help would be wonderful.
First, is there a difference (software, functions, box...) between BeoPort and BeoLink PC2 or just a name change?
Second, I saw that I could link my PC monitor with my Avant/DVD. From what I understand, I would need a TV tuner with a coax to the TV/DVD in order to carry the images over. Is this a good, stable, user friendly solution? Put it differently, what would be the drawbacks compared to a link TV? Do you recommend any TV tuner brand/model?
I've attached a drawing to represent the connections, if you are interested...
Thank you! Cheers.
