Latest post 04-16-2008 2:51 PM by Gerd. 2 replies.
Page 1 of 1 (3 items)
  • 04-12-2008 2:47 PM
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    MCL2AV
    I'm looking for the circuit diagram of MCL2AV type 2026 (or similar).
    The problem is: voltage on the 12v regulator is OK, no voltage at all
    on the 5V regulator and thus no power to the IR-receiver.
    Anybody with a circuit or experience on these?
    Gerd
  • 04-15-2008 7:20 AM In reply to
    • Xseries
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    Re: MCL2AV
    I have the service manual for the MCL system - it covers the type 2020 (not the 2026).  Unfortunatley my scanner has stopped working and I could only try and take pictures of the diagrams with a camera!  A quick look at the diagram and there should be 12v, 6 v and 5 v (for the microprocessor) outputs
    (I found that the ribbon cable had separated (it looked okay) on mine and with a new pair of strips it worked again! )
    Brian
  • 04-16-2008 2:51 PM In reply to
    • Gerd
    • Germany
    • Posts 523
    Re: MCL2AV
    Thanks Brian - I think the circuit of 2020 should do it if both voltage regulators
    12V and 5V are present in this one. A photo (macro?) of the circuit would be
    great. Check your "Inbox" for my e-mail.
    Cheers
    Gerd
