Latest post 04-21-2008 1:52 AM by Bieele. 10 replies.
Page 1 of 1 (11 items)
  • 04-19-2008 1:26 PM
    • Bieele
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Netherlands
    • Posts 339
    Beocenter 9500
    Today I reconnected my great beocenter 9500 which has been out of use for quite some time now.
    Had great fun hooking it up to my Mac Mini (to the Aux port) and my lovely beolab 4500.
    While playing with it I noticed something strange:
    When I play music on the Mac Mini over the beocenter 9500 and then switch to CD play (and keep the Mac mini playing music), the source changes to CD, but I keep hearing the Mac Mini music??!?! I would expect that the beocenter 'blocks' the aux port when turning to CD.
    Is this a defect or is this the way it should work?
    If it is a defect: any ideas how to solve it?
    Thanks,
    Bieele
    Heej zuij der alles veur gaeve En heej zaet ze mogen ut hebbe van meej
  • 04-20-2008 12:59 PM In reply to
    • Bieele
    • Netherlands
    • Posts 339
    Re: Beocenter 9500
    Maybe I should try to offend somebody to get some intention, this seems to work in other posts  ? Just kidding; but I would really like to get some feedback on my question!
    Thanks!
    Bieele
  • 04-20-2008 1:18 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Beocenter 9500
    Hi Bieele
    Ignore me if I'm speling drivel, but is, what you describe as 'AUX' actually  'A-Tape2'
    If so, then it would keep playing so that recording could be made. All pins would be connected so it was an in and an out connection.
    You could disconnect the unused pins........or just switch the Mac off.
    Sheer guesswork, probably total rubbish!
    Poor me, never win owt!
  • 04-20-2008 1:51 PM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Beocenter 9500
    You may well have ended up connecting the output if your BC9500 to the output of the MacMini (I made this mistake, my cables seem to be wired the wrong way round). When wired to the output, the sound will still appear (although it'll sound rubbish), but it won't go away when you switch to a different source.
     Weekly top artists:
  • 04-20-2008 1:53 PM In reply to
    • Bieele
    • Netherlands
    • Posts 339
    Re: Beocenter 9500
    Jandyt:
    Hi Bieele
    No rubbish at all; it does exactly the same at A-Tape2 as on Aux! I would expect for the AUX connection (for instance when in use for a tv sound input); that the sound would stop, even if the tv keeps playing, when selecting another source on the beocenter 9500.
    Any more ideas?
    Bieele
  • 04-20-2008 1:58 PM In reply to
    • Alex
    • Posts 2,990
    Re: Beocenter 9500
    Bieele:
    Jandyt:
    Hi Bieele
    Any more ideas?
    Bieele
    Did you try my suggestion? I had exactly the same issue as you with my BeoMaster 6500 when I first got it...
     Weekly top artists:
  • 04-20-2008 2:13 PM In reply to
    • Bieele
    • Netherlands
    • Posts 339
    Re: Beocenter 9500
    Hi Alex,
    I missed your post in the time I was reacting to Jandyt's post:
    After reading your post, my first thought was: This can not be the case since I used this cable before (and I had taped off the connections that I did not have to use). But your comment on the rubbish sound made me rethink this: I had to turn the volume up very high and still was not happy with the quality. Maybe I picked the wrong cable???
    So to be sure I rechecked and you were right on the spot! Wrong connections used! Thanks a lot!
    Still no idea how I ended up using the wrong cable, I can also not remember what I would have used this cable for in the past. I am getting close to 40 years old; I start to feel it!
    Thanks again!
    Bieele
  • 04-20-2008 3:47 PM In reply to
    • Alex
    • Posts 2,990
    Re: Beocenter 9500
    No problem! Again - this had me scratching my head when I first set up my BeoMaster 6500. Worked a dream with the CD7000, but all my 3rd party things sounded rubbish and were audible all the time. Thought the BeoMaster was faulty but it just turned out to be me being dull...
     Weekly top artists:
  • 04-20-2008 9:10 PM In reply to
    Re: Beocenter 9500
    Dear Bieele:
    I just acquired a mint BeoCenter 9300.  Would you please expand on how you connected the Mac Mini to your BeoCenter 9500?
    Are you playing lossless or mp3 files?  Is the sound going through the Mini's sound card?  Do you have DAC connected to the mini?
     I thought that the sound coming out of the mini's sound card (or just about any pc) would be poor.  Some connect an external DAC to bypass the computer's sound card.
    Any comments are greatly appreciated.
    Dario
    When I hear music, I fear no danger. I see no foe... Thoreau
  • 04-20-2008 9:28 PM In reply to
    Re: Beocenter 9500
    this may help... though about airport express, not mac mini.
    good dac comments though...
    http://forum.beoworld.org/forums/thread/71905.aspx
    • B&o bottle opener
  • 04-21-2008 1:52 AM In reply to
    • Bieele
    • Netherlands
    • Posts 339
    Re: Beocenter 9500
    darioazul:
    Dear Bieele:
    Dario
    I have the MacMini connected the audio out of the MacMini to the aux input of the beocenter  with a mini-jack to 7-DIN cable. On the mac-mini I generally have AAC coded audio files and on an attached hard drive several ripped DVD files. I have MediaCentral from Equinux installed to operate the mac-mini.
    I actually think the audio output of the mac-mini is not that bad, of course there is a sound quality difference compared to for instance CD play, but this is not really big to my opinion. I generally use it at relatively low volumes (it is my bedroom setup) and for that purpose it is very good!
    Regards,
    Bieele
