Latest post 04-21-2008 4:52 PM by j0hnbarker. 7 replies.
Page 1 of 1 (8 items)
  • 04-08-2008 5:45 AM
    • ANS
    • Not Ranked
    • Joined on 09-24-2007
    • UK
    • Posts 17
    • Gold Member
    Cables
    A quick question..
    Can I use subwoofer cables to connect a non B&O pre-amp/decoder to Beolab 6000/4000?
    The (thin) cable which I am thinking of using is the QED QONTOUR MSR-SW subwoofer cable. Are there any potential problems?
    Any help is greatly appreciated
    ANS
  • 04-08-2008 7:43 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Cables
    It should work fine, I personally believe difference in sound between cables, especially interconnects is all a load of hot air...
     Weekly top artists:
  • 04-08-2008 8:15 AM In reply to
    • ANS
    • Not Ranked
    • UK
    • Posts 17
    • Gold Member
    Re: Cables
    Thanks for the quick reply. The only reason for using the QED cable is because it is very thin and can be hidden away easily. As a bonus, it also matches the skirting board.
    The cable debate will be never ending - including the perceived benefits of "burning in" a cable.
    The only time I have known a digital interconnect cable fail to send any data was when  it was disconnected!
  • 04-08-2008 10:29 AM In reply to
    • camshaft
    • Top 150 Contributor
    • Pennsylvania, USA
    • Posts 575
    Re: Cables
    I agree with Alex.  For running amplified signals, sometimes wire thickness matters, and some types of wires need shielding, but past that there's really no difference.  Just because there is a debate about something doesn't mean we're not sure about the answer.  Cable burn in doesn't make a difference.
    -Austin (resident audiophile skeptic)
  • 04-21-2008 4:04 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Cables
    camshaft:
    Cable burn in doesn't make a difference..........
    ........, however, green cables definately perform better than purple ones.
    Poor me, never win owt!
  • 04-21-2008 4:07 PM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Cables
    Jandyt:
    camshaft:
    LaughingLaughingLaughing
    Brilliant!
  • 04-21-2008 4:35 PM In reply to
    • Puncher
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Re: Cables
    Medogsfat:
    Jandyt:
    camshaft:
    Brilliant!
    You may scoff but there is science to back up his claim!
    Green tends to have a soothing and harmonizing effect due to its closeness to nature and therefore produces a "natural" tone whereas the pigments use to achieve Purple have a higher permittivity, leading to a higher dilectric constant (i.e. capacitance), resulting in a less bright, warmer tone which is very well suited to valve power stages.
    It just goes to prove "Theres many a true word spoken in jest"
  • 04-21-2008 4:52 PM In reply to
    Re: Cables
    Just a quick endorsement of QED cabling. I've been using some QED micro cable to connect my Beomaster 8000 and Beovox Pentas, and have been very pleased with the results. Sounds really good and the cable is really thin and hides perfectly under my skirting boards. If you want a decent thin cable that can be installed discretely, then I would recommend this wholeheartedly.
