Latest post 04-14-2008 5:42 AM by ChrDH. 5 replies.
Page 1 of 1 (6 items)
  • 04-14-2008 3:31 AM
    • ChrDH
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Denmark
    • Posts 493
    Motorstand for MX6000 a bit off center
    Hi there
    I have been away for a while, among other things writing my masters thesis. But now I am back, at least until the hassle of working life gets to me.
    I have just acquired a motor stand for my MX6000, and redone the hole setup, hanging the ouverture on the wall ect. All in all very nice, except that when the MX switches off, it turns to the centre position, and then a little bit further, so that it is actually not in the centre, but a bit off centre. Can this in any way be adjusted, and if so how? or am I just being fuzzy? My VX7000 underneath the MX makes is easy to se that the tv is turned a bit to the right then switched off. Help appreciated.
    best regards
     Christian
    Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
  • 04-14-2008 4:07 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Motorstand for MX6000 a bit off center
    Hi Christian, hope your thesis went well.
    I might be speaking through the top of my head here but, try moving the MX to the position you want it to park when off.
    Then press 'Store' '0' 'Store'
    Andy T.
    Poor me, never win owt!
  • 04-14-2008 4:37 AM In reply to
    • ChrDH
    • Denmark
    • Posts 493
    Not a bad idea, will try that!:)
  • 04-14-2008 4:39 AM In reply to
    • ChrDH
    • Denmark
    • Posts 493
    Unfurtunately, it had no effect, it still goes too far to the right.
    br Chr.
  • 04-14-2008 5:27 AM In reply to
    • mhw
    • Top 500 Contributor
    • Joined on 06-29-2007
    • Norway
    • Posts 207
    • Gold Member
    When you turn it on, does it move to the correct position? Try press Store - Store, when you are in the Stand menu...
  • 04-14-2008 5:42 AM In reply to
    • ChrDH
    • Denmark
    • Posts 493
    The problem is when I turn it off, then it mooves to a position a bit too far to the right.
    br Chr.
