Latest post 04-14-2008 4:12 AM by Daniel. 10 replies.
Page 1 of 1 (11 items)
  • 04-13-2008 1:41 PM
    • TYG
    • Not Ranked
    • Joined on 04-13-2008
    • Posts 4
    LX5500 Questions. S-Video
    I just connected my computer to my LX5500 TV. The picture is Black and White. Ive tried to change to Pal and etc but it dont matter. Still black and white. What should the settings be like in order to get color? Or what is the trick? =)
     I also would like to know how to make the tv turn. Its works because when i turn on/off the TV it turns but i cant figure out how to do this using the remote.
     Thanks alot!
  • 04-13-2008 2:00 PM In reply to
    Re: LX5500 Questions. S-Video
    Welcome to the forum!
    SHIFT 9 toggles between S-VHS connector and AV1.
    What do you mean with "turn"? Do you have a motor stand? Which remote control do you have own?
    On the BL1000 you might try the button << and >> - though I´m not sure about this.
    Hagen
  • 04-13-2008 2:04 PM In reply to
    • mhw
    • Top 500 Contributor
    • Joined on 06-29-2007
    • Norway
    • Posts 207
    • Gold Member
    Are you connecting it through the S-VHS socket? Or via Scart?
    EDIT: Too late...
  • 04-13-2008 2:15 PM In reply to
    • TYG
    • Not Ranked
    • Posts 4
    I just found the s-video in att the back of the TV. So now i connect directly without scart. And now i cant find any piture at all. In the menu should i choose V.Tape-1 or somthing else?
     Yes I have a motorstand. But the <<< >>> dont work. Original remote. The motorstand might be broken, but it turns as i turn TV off :)
  • 04-13-2008 2:24 PM In reply to
    Press picture twice or three times and Stand will be shown. Then << or >> is used to turn.
    I assume you have a beolink 1000 (without the LCD like the Beo4).
  • 04-13-2008 2:27 PM In reply to
    • TYG
    • Not Ranked
    • Posts 4
    Oh thanks now it works! Now I dont have to get out of bed :) great
  • 04-13-2008 2:31 PM In reply to
    • TYG
    • Not Ranked
    • Posts 4
    The stand works that is. :)
    If you press Store twice when Stand is shown, the position is stored.
    So if you turn the LX on, it turnes to the preferred position.
  • 04-14-2008 2:57 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    Beobuddy:
    It doesn´t matter how many times I press [PICTURE], it works anyway. And I use [<] and [>] to turn the TV.
  • 04-14-2008 4:03 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Hi Daniel.Smile
    If that is the case, how are you managing to change your colour or brilliance settings?
    Andy T.
    Poor me, never win owt!
  • 04-14-2008 4:12 AM In reply to
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    Jandyt:
    No need to, it´s an B&O!
    No, seriously: I use [arrow up] and [arrow down] (the same I use for volume).
