I very recently purchased a pair of Penta III type 6631. They have been working fine since Sunday and I came home this evening and one has stopped working...
It does not appear any particular event has occurred, I just switched on the beocenter and there is only one channel - checked the passives on the MCL and all fine.
I checked the powerlink cables, swapped them over, nothing.
I dismanltled the amp assembly and I can't 'see' that any components have burnt-out - R73 looks like it has been getting hot in that the PCB is discoloured - but I removed the resistor and it tests fine. Checked for dry solder joints and burnt tracks - nothing.
The light stays green. The display works. When a signal is first applied some sound comes through the speaker for 1/2 second at much reduced volume to the healthy unit, then dies away to a whisper...
Any suggestions from the wealth of knowledge around this forum would be greatly appreciated before I go and buy a new board!
I admit I have driven them pretty hard last couple of days, but they were fine this morning...
Thanks, Steve
