Latest post 04-05-2008 6:46 PM by Stan. 7 replies.
Page 1 of 1 (8 items)
  • 04-05-2008 6:34 AM
    Beolab 2 to my Mac
    Hi
    I need a bit of help connecting my beolab 2 subwoofer to my mac. I have spoken to the Tech guys at B&O and they arent sure how to do it.
    I want to connect the beolab-2 to the computer and then connect my beolab 3s to that.
    Please/Please could someone give me advice
    Regards
  • 04-05-2008 7:05 AM In reply to
    Re: Beolab 2 to my Mac
    The easy way to do it, and the way I have my BL3s connected to my PowerMac, is to use a Beoport. This allows you to control the music by remote, also allows you to link the computer music to any other B&O you have in the house and has a Powerlink socket so that you simply connect that to your BL2 and then connect the BL3s to that.
    Otherwise it will be making up a lead - stereo minijack to Powerlink. I take it the problem is the switching voltage.
  • 04-05-2008 7:59 AM In reply to
    Thank you
    I never actually thought of using the beoport
    Any idea what the voltage is and what pins it is that actualy switch the beolab 2 on?
  • 04-05-2008 8:11 AM In reply to
    Looking at the service manual, greater than 0.5V is on, less than 0.5V is off, on Pin 4.
  • 04-05-2008 8:16 AM In reply to
    Quick picture!!
  • 04-05-2008 8:19 AM In reply to
    • mhw
    • Top 500 Contributor
    • Joined on 06-29-2007
    • Norway
    • Posts 207
    • Gold Member
    Maybe you can use the 5v from the USB, that way the bl2 is only on when your computer is on...
  • 04-05-2008 11:34 AM In reply to
    Thanks for all the help. I cant use beoport for dvds and video so I will try make my own cable up, running from the usb
    thanks alot for everthing.
  • 04-05-2008 6:46 PM In reply to
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    If you mean you cannot use BeoPort for DVDs and Videos on your mac, this is not true.
    BeoPort takes whatever audio the Mac sends it.
    Stan
