I helped a friend with a old speaker the other day, he said the bass was weak on one of the speakers, so we opened it up and found that the 25cm SEAS woofer was rusty on the magnet and some of the chassie, while the woofer in the other speaker fas fine and worked nicely. I recon the rust have corrupted the copper-threads inside, making the woofer less powerfull. Have any of you expecirenced anything like this with a 30 years old speaker?
br
Chr.
									    Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
