Latest post 04-02-2008 11:32 AM by timmer66. 3 replies.
Page 1 of 1 (4 items)
  • 03-31-2008 7:25 PM
    • timmer66
    • Not Ranked
    • Joined on 03-03-2008
    • Polson, MT
    • Posts 36
    BeoGram 4002 shutter light in tonearm went out
    Hello,
    I was just listening to a record when I heard it skipping - checking it out I realized the tonearm wasn't progressing forward.  Further investigation  proved that the shutter light is not on.  I don't know if it's burned out or if there is another problem.
    Any ideas where to start?
    Tim
  • 04-01-2008 11:06 AM In reply to
    • timmer66
    • Not Ranked
    • Polson, MT
    • Posts 36
    Re: BeoGram 4002 shutter light in tonearm went out
    4002 type 5503
    The light I am referring to is part# 3164196 - housing with lamp, that is under the diaphragm.   Is this something that burns out?
  • 04-01-2008 12:11 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    You will probably be replacing the lamp as a discrete component. I don't have the manual at hand but it's probably a 24V 25mA or so.
    You should be able to see it shine in the housing. If not, put a voltmeter across its wires. If you have about 20 volts or so and no light, the lamp is at fault.
  • 04-02-2008 11:32 AM In reply to
    • timmer66
    • Not Ranked
    • Polson, MT
    • Posts 36
    Thanks -    I just got done fine-tuning the tonearm and replacing the belts and cartridge.  It was working absolutely fantastic until this new problem.
    The concern I have now is trying to get to the lamp without taking apart more than necessary.
     Tim
