Latest post 02-19-2012 10:16 AM by Silou. 2 replies.
Page 1 of 1 (3 items)
  • 02-19-2012 7:36 AM
    • Silou
    • Top 500 Contributor
    • Joined on 08-10-2007
    • Switzerland
    • Posts 241
    • Gold Member
    Where is the SHIFT command into config tools?
    No found into the last CT???
    Is there a new name???
  • 02-19-2012 9:15 AM In reply to
    • hfat
    • Joined on 05-18-2010
    • Austria
    • Posts 176
    • Gold Member
    Re: Where is the SHIFT command into config tools?
    Although it cannot be selected from the list, you can add it manually by entering SHIFT into to command field and clicking add.
    hfat
  • 02-19-2012 10:16 AM In reply to
    • Silou
    • Switzerland
    • Posts 241
    • Gold Member
    it works thanks!!! I was sure that all commands was listed!!
