Latest post 02-05-2012 4:12 AM by rikarde. 2 replies.
Page 1 of 1 (3 items)
  • 02-02-2012 12:38 AM
    Mac - Beovision 10 - BC2
    Goodmorning to all (it atleast morning in Sweden) Cool
    I have a BV10 that I have connected my speakers, BC2 and MacMini to. The MacMini is connected to the BV with a HDMI cable. I have the TV set to PC and the mac screen appears. Picture and sound is good. I listen to music and movies. SOund out in the Mac is set to: Beovision.
    I also want to be able to listen to music without having the TV on. Does enyont know what to do here?
    I have tried to connect my usb-DA-Aux in to the BC2 no sound here. I can set the audio out to USBsound. But then I dont get the sound to my BV.. I dont want to change the settings all the time.
    When I have the BV set to PC - music out in the speakers I cant listen to the same source in my kitchen..
    I have a sqeezebox aswell, I can use that one to the aux, but it takes out alto of the soundquality..
    Does anyone have the same problem? Or better a solution :)
    BeoCenter 2, Beovision 10-46, BeoLab3, BeoLab4000, BeoLab3500, Beo4
  • 02-03-2012 10:34 PM In reply to
    Re: Mac - Beovision 10 - BC2
    rikarde:
    Because I have a BeoPort and LinkPlayer software I am ablw to get [N-NUSIC] in the Link Rooms as well as on the TV without the screen being activated
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 02-05-2012 4:12 AM In reply to
    I changed the setup so the macmini uses the command V-mem then it works great in the linkroom :)
