LifeStyle AV - Pre-owned Bang & Olufsen you can trust
Latest post 02-01-2012 12:07 PM by hprimdahl. 1 replies.
Page 1 of 1 (2 items)
  • 01-18-2012 5:31 AM
    ATV2 + Beovision 10 = choppy/stuttering playback
    The problem is very visible in sideways panning shots or on moving objects, which gets a choppy movements occuring every 5-6 sec. The exact same video files plays back fluently on a WDTV box. Tested with 720p and different lower resolution files. Also tried different output settings on ATV2, 720p 50hz or 60hz and 480p, but no luck.
    A discussion on the XBMC forum suggests disabling any motion improvement features in the TV, but i don't see any option for disableing the BV10s "Motion Picture Improvement" feature...
    Any thoughts or suggestions would be greatly appreciated.
    (PS. I have the same behavior when playing movies from my MacBook Pro via a mini displayport to hdmi adapter on the BV10.)
    Filed under: , ,
  • 02-01-2012 12:07 PM In reply to
    Re: ATV2 + Beovision 10 = choppy/stuttering playback
    To answer myself: Turns out my BV10 has some very early firmware with no option for setting game mode on or film mode off. Both should help remove lag and choppy playback.
    More info: http://forum.beoworld.org/forums/t/40782.aspx
STB Brackets - Flexible Mounting Solutions for Bang & OlufsenHygge Living - Bang & Olufsen Installation SpecialistsNeed a cable? Just ask Steve at Sounds HeavenlyBeo 5 remote control programming service
