LifeStyle AV - Pre-owned Bang & Olufsen you can trust
Latest post 10-28-2011 5:22 PM by beaker. 5 replies.
Page 1 of 1 (6 items)
  • 10-25-2011 8:51 AM
    Beocord 2000 de luxe (reel to reel) manuals ?
    Hello all,
    I've bought a very nice Beocord 2000 K de luxe reel-to-reel tape recorder, working specimen needing just cleaning and minor adjustments, I believe.
    I really like to put it in top condition and learn to use its many features (mixing, echo etc.) but it is a rather complicated machine, and I have previous experience only with much simpler tape recorders. Advice on its adjustments and advanced features are really appreciated!
    I haven't found User or Service Manuals for it (or fore any of its close "relatives" either) anywhere. Any idea if those manuals are available ?
    -jari
  • 10-25-2011 10:18 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocord 2000 de luxe (reel to reel) manuals ?
    This sheet originally came with the Beocord, is that what you need ?
  • 10-25-2011 10:25 AM In reply to
    Thank You ! These were a great help!
    -jari
  • 10-26-2011 7:14 AM In reply to
    I did have the users manual. Was very comprehensive. I thought i scanned it for the site but maybe not. I will have a look in my draws and see if I can find it. If I do, its yours. I do have the BC1500 manual which I could scan if you like.
  • 10-27-2011 4:08 AM In reply to
    Thanks, the BC2000DL manual would be great!
    Manuals for BC1800 and BC2400 are here as well, I think they are as close as the SC1500 manual for the real thing?
    -jari
  • 10-28-2011 5:22 PM In reply to
    Really sorry but the manual has gone. Any progress on the Whitley. The hurricane in the garage hasn't moved in 3 years. My fathers owned it for over 40 years and it's only done 40000 miles from new.
STB Brackets - Flexible Mounting Solutions for Bang & OlufsenHygge Living - Bang & Olufsen Installation SpecialistsNeed a cable? Just ask Steve at Sounds HeavenlyBeo 5 remote control programming service
