Latest post 09-12-2011 2:14 PM by BeoIce. 2 replies.
Page 1 of 1 (3 items)
  • 09-12-2011 3:34 AM
    • BeoIce
    • Top 200 Contributor
    • Joined on 03-27-2007
    • Recklinghausen, Germany
    • Posts 281
    Beoport and Windows 2003 Server
    Hi all,
    as I'm getting a beosound 9000 MK III soon, I would like to know if it is possible to use a Windows 2003 server with beoport instead of a normal pc. The server is already running 24h, so there would be no need to keep a second machine running.
    As far as I understand Beoport streams music over masterlink to a compatible audio system.
    How does everything else work ? Does it work like streaming videos/music from a nas ? I currently have this windows 2003 server and a playstation 3 to stream movies from the server to my tv. Beoport should do the same but to the beosound 9000.
    Is my understanding of beoport right and will it work as I want it to work ?
    Regards
    BeoSound 9000 MK III, BeoLab 6000, BeoLab 11, BeoCenter 2300, BeoSound Century, BeoVision MX4000/MX7000 & BeoCom 4
    Samsung UE40B7090, Samsung HT-WS1G, Technisat HD8-S, Sony PS3, Logitech PS3 IR-BT-Adapter & Lintronic TT455-RT-238
  • 09-12-2011 1:27 PM In reply to
    • lano
    • Not Ranked
    • Joined on 04-25-2010
    • Posts 66
    • Gold Member
    Re: Beoport and Windows 2003 Server
    Hi!
    The Beoport is to connected to your server with one USB cable for communication and line-out for the sound. The sound that is sent out on the masterlink is analog so it's not like streaming in that context.
    I have tried to install Beoport on my W2008 and the installation went fine, but the server will not recognize the internal sound card. I'm now thinking of getting a new sound card for the server (http://www.asus.com/Multimedia/Audio_Cards/Xonar_Essence_ST/). Sometimes also the software behaives a bit strange when do changes in the settings. But once running it seems to work.
    If have your line out working on the server i think it should work.
    /Lars
  • 09-12-2011 2:14 PM In reply to
    • BeoIce
    • Posts 281
    Hi Lars,
    thanks for your answer. Have you tried to enable Windows Audio in Windows Server. As long as it's not enabled Windows will not work properly with a sound card. You can find it in the management console right under services.
    I use Windows Server 2003 on a Acer H340 Home Server, which does not have any sound card, so I'll have to use a pci-express card as you mentioned in your link.
    Must Beoport run as an application on the server with a user logged on to or does it run as a service ?
    Regards
