I have a Beomaster 6500 with a short circuit. Need some help to find where the problem is.
The symptoms are: When i plug in the power cord the fuse T4A that sits between the transformator and the diod bridge blows. It sounds like its when the relay switches on.
The BM worked a few weeks ago and have been on the road in a car for some cold days. It's been sitting in a warm room for 24 h with the hood of in case there was condens or something.
Anyone have a idea where to start looking? Cant see any burned components...
Thanks för any help in any direction.
/Karl Nilsson
