LifeStyle AV - Pre-owned Bang & Olufsen you can trust
Latest post 02-28-2012 11:01 AM by olemol. 2 replies.
Page 1 of 1 (3 items)
  • 02-27-2012 8:32 PM
    • olemol
    • Not Ranked
    • Joined on 02-22-2012
    • Posts 4
    Connecting Macbook Air + Iphone 4 to BL3?
    Hi Beoworlders!
    I am currently watching my mailbox for my new (and first B&O product) Beolab 3s, and prior to get them in house i need to prepare how to connect them to my Macbook and Iphone. Have heard that its quite simple setup with the Apple Airport Express.
    -Have anyone tried it before? can i shuffle between macbook and iphone as the music source? or can it only be set up with one of them at the time?
    -Do i need any cross-over cables to connect the bl3s to the AExpress?
    -How do I set up iTunes to play wireless? can it be played wireless?
    Thanks for answering! Cant wait for postman pat! :D
    Ole
  • 02-28-2012 10:50 AM In reply to
    Re: Connecting Macbook Air + Iphone 4 to BL3?
    olemol:
    similar, and so have others
    olemol:
    yes
    olemol:
    each iDevice can "talk" wirelessly to the AE, I presume that last one to talk will gain control (that is how my ATV tends to work)
    olemol:
    you will need a mini-jack stereo splitter and then these cables from B&O:
    ...To a non-Bang & Olufsen system:
    Use a special adapter with an ordinary phono/RCA plug in one end, and a DIN-plug in the other (optional accessory, available from your Bang & Olufsen retailer). Remember to set the SETUP switch to LINE.
    olemol:
    good question ! I thought it was a preferences setting, but I can't find it now - look for a small arrow on the bottom right hand corner of the iTunes window - clicking it should present you with a choice of the Macbook's speakers or the AE
    olemol:
    yes
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 02-28-2012 11:01 AM In reply to
    • olemol
    • Not Ranked
    • Posts 4
    thanks a lot! great answer :)
STB Brackets - Flexible Mounting Solutions for Bang & OlufsenHygge Living - Bang & Olufsen Installation SpecialistsNeed a cable? Just ask Steve at Sounds HeavenlyBeo 5 remote control programming service
