LifeStyle AV - Pre-owned Bang & Olufsen you can trust
Latest post 02-01-2012 4:59 AM by PhilLondon. 1 replies.
Page 1 of 1 (2 items)
  • 02-01-2012 2:39 AM
    • carlito
    • Top 500 Contributor
    • Joined on 04-19-2007
    • Switzerland
    • Posts 97
    • Silver Member
    Beolab 5 and Linkplayer
    Is anyone using Linkplayer with the Beolab 5. My Audiomaster is a Beocenter 2.
    Problem! The Speakers are turning on the Digital Input only when pressing "CD" on the Beo4....
    Any Configuration ideas for this approach?
    Cheers
    Carlo
  • 02-01-2012 4:59 AM In reply to
    Re: Beolab 5 and Linkplayer
    This is because CD is the only digital source that your Beomaster can send directly to the Beolab 5.
    The Beoport sends the music to the Beomaster through MasterLink, which is analog.
    What you could try, is connect the digital sound output of your mac directly to the digital input of your Beolab 5, and see if it turns on when you press N.MUSIC.
    p.
STB Brackets - Flexible Mounting Solutions for Bang & OlufsenHygge Living - Bang & Olufsen Installation SpecialistsNeed a cable? Just ask Steve at Sounds HeavenlyBeo 5 remote control programming service
