Latest post 01-20-2012 9:31 PM by jk1002. 3 replies.
Page 1 of 1 (4 items)
  • 01-19-2012 5:02 PM
    • Beofan2
    • Top 200 Contributor
    • Joined on 07-31-2007
    • Fredericia, Denmark
    • Posts 313
    IPad dock
    Rumours says IPad 3 will be revealed next month or march. Will the also rumoured IPad dock from B&O Play be revealed february or march? No doubt Apple will sell a lot of the "3",  B&O Play could sell a lot of the dock if released at the right time. Can anyone reveal some additional information on this new dock? And possible launch date?
    It´s not magic - it´s Bang & Olufsen
  • 01-20-2012 2:14 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    Re: IPad dock
    The launch should be in the near future (March/April). The iPad slides in, it will keep the iPad in the same viewing positions as the current smart cover (but obviously this dock/cover is fixed). The built-in speakers are the real bonus. Hopefully the iPad 3 will keep the dimensions of the iPad 2... It is a bit like the BeoTime: a must-have to some, others will not see the point of this cover/dock as it adds bulk.
    Roger
  • 01-20-2012 3:27 AM In reply to
    Re: IPad dock
    That's a big gamble both for B&O and the buyer as the iPad will undoubtably change every 1-2 years...
  • 01-20-2012 9:31 PM In reply to
    Re: IPad dock
    I dont think the base model will change much in format.
    It might be easy to adjust the product to slightly different shapes, also price point is lower then normal B&O so why not. It might also be possible, just like docks, to design it flexible to adopt to slight modifications like a change in thickness
    While I am not interested in thr Beolit, this one I might get if it works with Ipad 3 which is my next since I am still on Ipad 1. For travel, it might be interesting.
