Latest post 07-06-2011 3:23 AM by Milton78. 6 replies.
Page 1 of 1 (7 items)
  • 06-20-2011 11:09 AM
    Loose glass plate on BS 9000
    Calling out to all of my fellow B&O-lovers who have a better knowledge than I possess of the technical side of this piece of machinery. The issue is the following: I have been offered to purchase a used BS 9000 with a loose glass plate. Now, how damaging is this, i.e. how difficult is it to repair? And also, some of the external cabling has been changed so it'll need to be remade.
    I don't intend to do this myself, unless it's REALLY easy, but some kind of estimate would help before I ask the repair people.
    /Carl-Henrik
  • 06-21-2011 1:31 AM In reply to
    • Bieele
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Netherlands
    • Posts 339
    Re: Loose glass plate on BS 9000
    I would not be to concerned about the cabling; can be quite easily fixed.
    Loose glass plate needs professional repair, I would have someone look at it before I made the final purchase.
    Bieele
    Heej zuij der alles veur gaeve En heej zaet ze mogen ut hebbe van meej
  • 06-21-2011 3:50 AM In reply to
    Is the BS9000 old? I think the glass plate coming off was a problem in early production, and there was a factory recall for it. There's still a chance that it might be repaired (new door) for free - if you can get the serial number from the seller, it might be a good idea to ask a dealer about it.
    -mika
  • 06-21-2011 4:08 AM In reply to
    Hi guys,
    Thank you both for your advice! I will ask my dealer about it once I can locate the serial number.
    /Carl-Henrik
  • 06-21-2011 4:30 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Milton78:
    Best scenario:
    Glass been opened by force -  just needs to be "snapped in" again
    (some "gentle" force needed, consulting a dealer/service technician recommended)
    Most likely when items is 10-15 years old:
    Glue between glass and the metal bracket(s) failed - replaceing the glass required
    (order sparepart - follow the supplied mounting instructions - not very complicated
    DIY job if you have the right tools eg. hex-key, ...)
    Worst case:
    Hinges have been damaged - definitely NO DIY - have to be replaced by a B&O trained
    service technician.
  • 06-21-2011 4:33 AM In reply to
    • Vienna
    • Posts 712
    Milton78:
    ... once I can locate the serial number ...
    Smile detach the "keyboard" and have a look ...
  • 07-06-2011 3:23 AM In reply to
    Got it!
    I just wanted to share an experience I had with this BS9000. As the plate was loose, and it was in unknown shape otherwise (it powered up but the CD-player was in lock mode) I had to turn it to a proper repairman. My original dealer has, sadly, closed his business and although there are some other shops around in Stockholm, I am not conveniently closer to one. Thus, I had to go shop hunting!
    I sent out a request to two shops - one old that's been around for some time and one new in a brand new upscale shopping centre. The old one replied quite fast, with good answers and a "Yes, we can"-attitude. The other (newer one) just directed me to the repairshop..."You can call them at...." and was not helpful at all! Now,  I know I am not a customer of theirs but I would think they would have liked me as a customer! If more B&O are like this new one, no wonder they've all disappeared! Perhaps B&O should include some business thinking when accepting a new dealer. Smile
