LifeStyle AV - Pre-owned Bang & Olufsen you can trust
Latest post 01-13-2011 12:07 PM by hagan. 2 replies.
Page 1 of 1 (3 items)
  • 01-11-2011 5:37 AM
    Ir codes for Motorola vip 1003
    Does anyone know if any of the motorola ir codes in the puc list works the vip 1003 iptv stb?
    regards
  • 01-11-2011 3:01 PM In reply to
    Re: Ir codes for Motorola vip 1003
    You have raised an interesting question here, so I decided to do a little research and the following are my findings:-
    The Motorola VIP 1003 uses either a standard NYX remote or a MRCU180 optional remote which has a keyboard one side and a normal remote the other side and will also support other TV and audio products including apparently B&O. However the MRCU180 was only announced by Motorola in September 2010 but does support almost every IR protocol you can think of.
    The B&O PUC library supports several Motorola VIP products as below:-
    • VIP1200      which uses 36 Khz Carrier Frequency with 32 bit Manchester Coding
    • VIP1216      which uses 36 Khz Carrier Frequency with 32 bit Manchester Coding
    • VIP1216E    which uses 36 Khz Carrier Frequency with 32 bit Manchester Coding
    • VIP1910-9   which uses 56 Khz Carrier Frequency
    • VIP1960      which uses 56 Khz Carrier Frequency with Philips RCMM protocol
    • VIP1903      which uses 36 Khz Carrier Frequency with unknown protocol
    If you are able to capture a IR command from your original remote, then we could be sure which, if any would work.
    Regards Keith....
  • 01-13-2011 12:07 PM In reply to
    Hi and thanks for your help.
    I managed to get my Motorola 1910 repaired instead of buing a new one. I learnt that 1910 and vip 1003 can not use the same remote so I thought, better repair than get a new box which might add an ugly remote Embarrassed
    Unfortunately I can not confirm that any of the listed stb-codes work with vip 1003
    br
    /n
STB Brackets - Flexible Mounting Solutions for Bang & OlufsenHygge Living - Bang & Olufsen Installation SpecialistsNeed a cable? Just ask Steve at Sounds HeavenlyBeo 5 remote control programming service
