Latest post 10-07-2011 7:14 AM by Guy1680. 48 replies.
Page 1 of 2 (49 items) 1 2 Next >
  • 09-30-2009 7:56 AM
    Beo1
    Hello
    Is it possible to use Beo1 to other than beovision1 ....? it is possible to configure it so you get some features to work on other Bang and Olufsen equipment
    /Uldall
    Beosound century Beocenter2 Beolab2 Beolab3 Beolab8000 Beolab6000Black Beolab4000 Beovision Avant 32 DVD RF MX7000ML MX4200ML MX1500 Beolink1000 Beo1 Beo4 Beo5 Beosound1 Beosound6 Beocom2 Beocom6000 Serene BeoPort A4 A8 A9 LC1 LC2 Kabinet 2168 Black line FORM1 Beotime Beotruck.
  • 09-30-2009 8:01 AM In reply to
    Re: Beo1
    As far as I am aware it only works on early BV1 and BC1 and it is not possible to re-configure it.
    Regards Graham
  • 09-30-2009 8:18 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Beo1
    As said before I have reprogrammed my Beo1 to standard Beo IR codes. So I can use it with my BV7-40 MKIII, BS9000...
    All buttons are working like Beo4 buttons.
    See : http://forum.beoworld.org/forums/t/13515.aspx
    Stefan
  • 09-30-2009 9:44 AM In reply to
    • hebo
    • Top 200 Contributor
    • Sweden
    • Posts 305
    Re: Beo1
    Stefan,
    I can´t get it to work.
    Would be nice to be able to use the Beo1, not just have it standing as an artpice:-)
    I´m pressing Standby+Display+Stop at the same time then
    pressing Stop and holding then pressing double arrow right, and release the two
    then pressing Display once
    Is this the right way to do it???
     BV10
  • 09-30-2009 10:25 AM In reply to
    Re: Beo1
    Stefan.
    Marvelous trick,
    it works!
    Hebo, you got the instruction right.
  • 09-30-2009 11:59 AM In reply to
    • stefan
    • Posts 1,733
    Re: Beo1
    hebo:
    Stefan,
    Hi Hebo,
    yes you got that right. Strange, some people got it to work, some did not.....??
    Mine is working like a Beo4 - but no colored buttons, no EXIT...
    Stefan
  • 09-30-2009 12:23 PM In reply to
    Re: Beo1
     I tried but unfortunately does not work
  • 09-30-2009 1:08 PM In reply to
    • hebo
    • Sweden
    • Posts 305
    Re: Beo1
    claudiu:
    Claudiu,
    we probably have greater luck in other areasBig Smile
     BV10
  • 09-30-2009 1:09 PM In reply to
    • Toubro
    • Copenhagen, Denmark
    • Posts 263
    Re: Beo1
    No way...
    I know this might not be the most manly thing to say, but I love you guys. I have had my Beo1 ever since my parents BV1 got stolen in 2002, and I have just had it standing as a piece of art, and even though several people have asked me if they could buy it, I have kept it because I think it is so beautiful designed. That I can actually use it again is fantastic. This has really made my evening Big Smile
    At first I couldn't get it to work, because I hadn't seen the last "display" button press, but now it works fine on my Avant. I can't believe it didn't do this as standard, but that it is still capable.
    Cheers guys Yes -  thumbs up
  • 09-30-2009 1:22 PM In reply to
    • hebo
    • Sweden
    • Posts 305
    Re: Beo1
    Now I just wait for mr_anders_son to report his status with his Beo1Smile
    or maybe he is to occupied with his BeoTimeBig Smile
     BV10
  • 09-30-2009 1:23 PM In reply to
    • hebo
    • Sweden
    • Posts 305
    Re: Beo1
    edit double post
     BV10
  • 09-30-2009 2:43 PM In reply to
    • RayTheWash
    • Top 500 Contributor
    • South East London
    • Posts 93
    Re: Beo1
    ...cannot get mine to work either Sad
    are there different software versions of the Beo1?
  • 09-30-2009 4:02 PM In reply to
    Re: Beo1
    Hey unfortunately I can not get in Beo1 to respond to the configuration ...Sad
    It might be the software..
    Anybody knows if there are differences in software from which they are produced...??
    /Uldall
  • 10-02-2009 10:26 AM In reply to
    Re: Beo1
    Yes
    Finally I got my Beo1 to work, it work´s perfectly for MX7000 MX4200Big Smile
  • 10-02-2009 11:51 AM In reply to
    • hebo
    • Sweden
    • Posts 305
    Re: Beo1
    Uldall`s:
    Yes
    What´s the trick?
    How did you do?
     BV10
  • 10-02-2009 1:21 PM In reply to
    Re: Beo1
    I changed the batteries and tried again and so did it work ...Big Smile
    /Uldall
    Re: Beo1
    /Uldall
  • 10-02-2009 1:22 PM In reply to
    Re: Beo1
    /Uldall
  • 10-02-2009 5:56 PM In reply to
    • Toubro
    • Posts 263
    Re: Beo1
    It's funny, because I couldn't get it to work at first, and I then thought about the fact that it had been standing on my cabinet for a very long time. After a battery change it worked like a charm Yes -  thumbs up
  • 10-03-2009 12:45 AM In reply to
    • Dave
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Re: Beo1
    Hey how come this doesn't work for me? I've tried it three *edit:seven* times now (battery changed and everything)
    - standby+display+stop at same time
    - then hold stop and press >>
    - press display
    Batteries are not flat... i'm baffled! I'm so jealous you guys got it to work! I have a BV3 and BC1 with Beosound 4, my Beo 1 doesn't work after this trick...
    Does it have to be done very fast, does standby display and stop have to pressed in order..?
  • 10-03-2009 1:25 AM In reply to
    Re: Beo1
    Dave:
    - press display
    try:
    press standby keep holding it
    press display keep holding it
    press stop keep holding it
    release all of the three
    press stop keep holding it while pressing >>
    release both
    press display
  • 10-03-2009 1:43 AM In reply to
    • Dave
    • Posts 2,328
    Re: Beo1
    :( there must be different versions of Beo1. It doesn't work, my serial number is 15665441
    Shame really!
  • 10-03-2009 6:01 AM In reply to
    • stefan
    • Posts 1,733
    Re: Beo1
    Maybe that`s the trick: Remove batteries just to reset the Beo1. I remember I had to install batteries first, because my Beo1 was standing on a bookshelf for months without batteries....
    Stefan
  • 10-03-2009 4:35 PM In reply to
    • Dave
    • Posts 2,328
    Re: Beo1
    Can anyone post their serial number for those that worked? I think i have one of the first Beo1's out, maybe if i order a new PCB it'll work
  • 10-04-2009 5:15 AM In reply to
    Re: Beo1
    Dave:
    - press display
    mine works with thisWink
